AUDI A6 C5 1,9TDI, AFN
Cveles
Postovi: 446
Lokacija: Beograd - Nis
Post od Cveles » 7 years ago
Evo i ja da otvorim novu temu i predstavim novi auto... ko je bio na skupu u S klubu imao je prilike i da ga vidi... a dok ne stigne malo lepse vreme da ga operem, stavim okvire i nalepnice i slikam bice jedna slika sa oglasa pre nego sam ga kupio...  I ono sto jesam uradio, mnogi mi rekli i rekli bi da sam lud...ali sam ga kupio u petak i u subotu prevalio 300km da bih stigao na skup i video da nisam pogresio sto sam ga uzeo... auto se pokazao super na putu, lepo lezi, lepo ide... maksimalno ga poterao 190 jednom, vise nisam smeo za sada... na Avalu izasao u trecoj brzini bez problema... a polako sa vremenom ce biti jos nekih stvarcica...
Znam... plav je enterijer...al sta da se radi... :))) Od opreme uglavnom klasika, nista posebno...
1998 Audi A6 1.9 TDi
body type 4/5 seater sedan/saloon
number of doors 4
wheelbase 2760mm
track (front) 1540mm
track (rear)         1569mm
length         4796mm
width          1810mm
height         1453mm
kerb weight 1365 kg
fuel tank capacity 70 litres
drag coefficient 0.280
frontal area 2.19 m²
engine type turbocharged diesel
engine manufacturer Volkswagen
cylinders Straight 4
capacity 1.9 litre 1896 cc
bore × stroke 79.5 × 95.5 mm
bore/stroke ratio 0.83
valve gear SOHC
2 valves per cylinder
8 Total valves
maximum power output(din) 109.5 PS (108 bhp) (80.5 kW)at 4150 rpm
maximum torque(din)                 235 Nm (173 ft·lb) (24 kgm)at 1900 rpm
compression ratio 19.5:1
fuel system Bo VP 37 direct diesel inj.
engine coolant Water
cylinder volume 474
aspiration Turbo D.
compressor 1 VTG turbocharger
intercooler Y
catalytic converter Y
acceleration 0-80km/h (50mph) 8.50 s
acceleration 0-100km/h 12.30 s
maximum speed 194 km/h (121 mph)
engine position front longitudinal
drive wheels front wheel drive
steering rack & pinion PAS
brakes f/r VeDi/Di-ABS
gearbox 5 speed manual
top gear ratio 0.68
final drive ratio 3.70
model family C5
Prikačeni fajlovi
Slavko Cvetkovic-Cvele, Beograd - Nis, Audi A3 8L 1.9TDI, 2001. 1896ccm, 74kW (100KS)
Audi 100 C3 1990 (2.0 TD, 74kW)
Audi A6 C5 1998 (1.9 TDI, 81kW)
Odg: AUDI A6 C5 1,9TDI, AFN
Post od jevrem » 7 years ago
Prvo evo i ovde da uputim cestitke na kupovini. I mogu samo reci da imas lepe osnove da sredis kako treba. ;)
imperialbma
Postovi: 983
Post od imperialbma » 7 years ago
Cestitam i ja ovde  *beerandmusic*
Drago mi je sto ostade veliki auto. Pogotovo sto ces se dosta voziti na Autoputu.
Sad imamo isti auto  *chears2* *chears2* *chears2*
Audi A6 1.9 TDI 130KS 2002.G.
Cveles
Postovi: 446
Hvala Jevreme i Zeljko.... pa iskreno i meni je drago sto ostade veliki... :))) bio sam u dilemi izmedju toga i neceg malo mladjeg ali ipak ispalo je tako da je ovo odnelo prevagu... Nadam se da ce preci dosta na Autoputu i na razne skupove sa najboljim drustvom iz kluba...  *beerandmusic* *beerandmusic*
Haha...nek bude da je isti... :)
Lemilica
Postovi: 84
Lokacija: Novi sad
Post od Lemilica » 7 years ago
U zdravlju da te dobro sluzi da predjes dosta kilometara i da bude bez  *carfix*
Audi A6 2.5TDI 2000god
sasa72
Postovi: 76
Lokacija: PODGORICA;CG
Post od sasa72 » 7 years ago
sa SRECOM,ja ga imam vec tri godine,odlican auto i sto rece Jevrem imas odlicnu osnovu da ga sredis tip top! *goodjob*
sasa A6
rajmax63
Opšti urednik
Opšti urednik
Postovi: 1002
Lokacija: Backa Palanka
Post od rajmax63 » 7 years ago
*bravo* Cvela na kupovini
Auto sam video i mogu reći da baš lepo izgleda.
To što je plavi enterijer ako bude bilo nešto povoljno pomoćemo ti da ga zameniš ali otom potom
Ako ti neki deo oko enterijera zafali samo javi
Kod mene te čeju oni mali poklopčići za čaše napred i nazad
blago onom ko rano poludi pa mu zivot prodje u radosti i veselju
marko 80
Postovi: 381
Post od marko 80 » 7 years ago
Neka je sa srecom kupovina i da se lepo navozas sa njim.
Audi 80 1.8s
Postovi: 4488
Post od LeSto89 » 7 years ago
cvele uzdravlje da se navozas  *beerandmusic*  *zelembaci* *jupi*
max audi
Postovi: 213
Lokacija: Palilula Bg - Babusnica
Post od max audi » 7 years ago
Druze, neka je sa srecomlimuzina,  auto lepo izgleda ovako, ne mari za plav enterijer to se da promeniti, ako je sve drugo u super stanju! NEka te lepo sluzi, bez kvarova!!  ;)  *beerandmusic*
Audi A4 B6 1.9TDI / 96kw
Postovi: 15402
Post od Nemanja » 7 years ago
Cvele cestitke jos jednom na sestici! *chears2*
Da vas vozi u zdravlju.
Ja cekam slike sa svim obelezjima ACS. ;)
I zelim da ti ponudim i da castim tvoj novi auto, sa mojim enterijerom sto je bio kod mene u autu.
Znaci sve ti poklanjam bez ikakve materijalne nadoknade. Naravno ako se tebi taj enterijer svidja i ako bi zeleo da zamenis ovaj plavi.
Nemas samo vozacev tapacir, jer je on prodat. To bi ti ja nasao kod nasih sponzora na otpadu, ili ako je povoljnije na ebay-u da nadjemo.
Ako si ZA, ti se javi pa da te uputim na Jevrema, jer mi to sve stoji kod njega u garazi u Smed.Palanci.
Jos jednom sve najbolje! :-*
marko_kalauz
Postovi: 418
Lokacija: Budjanovci
Post od marko_kalauz » 7 years ago
Evo i ja da cestitam na kupovini oooo.  *bravo*
Stvarno treba imati hrabrosti dan posle kupovine i preci sa njim toliki put, ali je vredelo.. ;)
Just the end justifies the means!
Cveles
Postovi: 446
Nemanja napisao: Cvele cestitke jos jednom na sestici! *chears2*
Ne znam sta da ti kazem Nemanja, osim jedno veliko Hvala... naravno da sam za, jer je u dosta boljem stanju od mog, nevezano za boju... a taj jedan cemo vec naci negde da se uklopi... tako da sam svakako za... cucemo se i dogovoriti, najmanji problem...  *spray* *beerandmusic*
Postovi: 15402
Nema na cemu.
Za ljude kao sto si ti, nista nije problem.
Javi se onda, pa da se sve dogovorimo.
Ljubi Bogdana.
Pozz
Quattro
Postovi: 1350
Lokacija: Aleksinac-Zitkovac
Post od Quattro » 7 years ago
*beerandmusic* da te dobro sluzi, cestitam  *chears2*
Zaključana tema
Povratak na “A6 1997-2004 C5 typ 4B”
